Thread: Help! Old Poseidon 21' Above Ground Pool Needs Parts
    Metairie, La.
    10
    I need help finding parts for an older above ground pool that came with the house I purchased. I have what appears to be the original instruction manual. It is listed as a Poseidon Aluminum Granada Pool. I measured it at 21' round and 48"deep. The company is Poseidon Pools Inc. 168 39th Street Brooklyn New York 11232. I've been searching the Net and I cannot find anything on this company.
    -Has anyone heard of Poseidon Pools or know where to get replacement parts?
    -I need new T Clamps for the uprights to replace all that are missing.
    -I am also in the process of changing the liner. The skimmer is cracked and I need to find a new skimmer that will fit the holes previoulsy cut and drilled. I have a replacement gasket that was left that is a swimline hydrotools gasket part #8946. After researching it, it appears this gasket fits hydrotools skimmer model 8940. Can I make this connection and assume I should order a new 8940 skimmer as a replacement. I cant find any measurements for the 8940 on the Net to check.
    Thanks!!
    10,000 Gallon, 21' Round, Above Ground(Dug in 3/4), Sand Filter, Hayward SP15922S Power-Flo Matrix 1 HP 2-Speed Pump, Date = old, Spitting Fish Water Feature, Polaris Turbo Turtle Auto Pool Cleaner, Located in S.E. Louisiana
    Metairie, La.
    10
    Re: Old Poseidon 21' Above Ground Pool Needs Parts
    Here are some pics of the manual I found for the pool.
    Thanks!
    Metairie, La.
    10
    Anyone? Here are some of the pool before the winter leak and new deck..
    Metairie, La.
    10
    Re: Help! Old Poseidon 21' Above Ground Pool Needs Parts
    Man I wish I had a pool to swim in.
