Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Intex 16x48 Ultra Frame with Fencing
    Mar 2012
    Cincy, Ohio
    12
    Hi, I figured I would share our success with pool fencing on an Intex. I hunted all winter to see if it was possible and finally came across one mention of it. So, we took the dive and tried it. Here is a pic to show it is doable. The hubby had one spot that did give him an issue so he will attempt to fix itWe just finished it up this evening so please ignore the landscaping and my dug up yard (that's this week's project The driveway had to be dug into in order for us to fit the pool and now needs fixing
    Jen
    Pool: Intex Ultra Frame 16x48 AGP 5061 gal With Pink Foam Underlayment
    Equipment:Intex SWG, Intex Pool Light, Still Needing To order new Intex Sand Pump
    jsf0656's Avatar
    Apr 2010
    south georgia
    313
    Re: Intex 16x48 Ultra Frame with Fencing
    that looks great!
    18x52'' intex AGP, 6981 gal, 2650 intex sand filter,
    thru wall skimmer, SWG, 52'' 20G overlap liner, intex pool light
    That is awesome! Can you post where you got it and what it is called. That would make me feel a little better about going to work all day while the neighbor kids are on summer break. Also, maybe i'm missing it, but can you post a picture showing the ladder,or however you get in. Thanks!
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Mar 2012
    Cincy, Ohio
    12
    Thanks to both of you. We purchased the fencing from here http://www.abovegroundpoolsafety.com/. This type fencing is available many places online including Amazon. I specifically purchased this brand from this specific place as it was the one that I found on the representative Intex pool picture I found and I was worried if I tried any other brand, it might not work. But, there is nothing different that I can see about this specific brand that would be different than the others. I think they are all quite straight forward.
    As far as the ladder area, I will snap some pics of that today, we left one open span to place the better ladder we have on order. We will be using this one http://www.aquasupercenter.com/produ...ign=amazon+ads But, I can mention that they make a "gate" for this fencing so, you could use that if you are not placing a ladder that will stay in the pool all of the time.
    I specifically wanted this fencing as an additional barrier. My husband was worried it would look not so good. He has totally changed his mind. After this went up on the pool, it made this Intex look more like a traditional above ground pool. I personally do not think the picture does it justice on how much it changed its appearance.
    Jen
    how does it mount to the posts?
    Did anyone else try this? Was the fence light weight?
    This lookg great. Will you be taking the pool down off season and winterizing it?
    16x48 Intex ultraframe, Intex 14" 1600gph 1/2hp sand filter pump
    I just got off the phone with the 800-number in the post regarding the purchase of this fence. They said they would be out of stock for this season. Anyone know anywhere else to purchase the fencing ?
    Apr 2014
    Ohio
    1
    How easy was it to attach? I've been looking for fencing for Intex Ultra frame that we're looking to purchase. Yours in the 1st pic. It looks great.
    Jun 2013
    west fargo
    72
    Quote Originally Posted by Mdmoons View Post
    I just purchased the same exact fencing from amazon and it looks like it will be pretty simple to attach.
    The only thing I see being challenge is you have to have the same amount of sections as you have poles on the pool.
    I don't plan to get it put on until late May early June I am starting a whole new Pool project. But I will keep you posted.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Mar 2014
    Thomson GA
    166
    You will have an awesome view from the pool.
    Gerry
    27' x 54" AG Salt Water Pool Installed 2014, Hayward 23" Sand Filter, 1 HP 2-Speed Power-Flo Matrix Pump, AQ-TROL SWG, TF-100 Test Kit
    May 2014
    Louisville, Ky
    5
    So I am curious about the ladder. I have 4 year old twins and will be using the same fencing. I was thinking of ordering the gate as well to use with the ladder that came with the pool, but I really like the type of ladder you purchased. I'm concerned however about leaving one section open without fencing even if they can't use the ladder. Thoughts or comments?
    May 2014
    Owen Sound, ON
    44
    I was looking at a fence from Vinylworks Canada, available at Costco, and there is a section of fence that is movable available if you were taking in and out your original ladder. They also mentioned that you can cut the fence to length for the right fit, with brackets for the ladders with the locking mechanism. Not sure about other companies. I am considering this option.
    Jun 2013
    west fargo
    72
    Ya one section would have to be part ladder part stairs. But they do sale a gate I would guess it covers a full section.
    20'x54" intex ultra Sand filter. with SWG Still work in progress will have Resin 24" fence around the top. Hooked to a 10x6 Deck that is attached to another 10'x6' Kids Club house. Slide from main deck into pool. Intex softwall lights. Kenwood Marine radio sealed in a deck box all Bluetooth controlled with Pyle 5" outdoor speakers.
    Jun 2015
    Crete, il
    1
    Anyone have pictures or thoughts about intex fencing for 14' round ultra frame?
    Jul 2015
    Delta
    9
    Any update??
    Jul 2014
    Oakbank, Canada
    389
    Quote Originally Posted by Hayley15 View Post
    Any update??
    Update of what? The original post showed completed fence installation.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Jul 2015
    Delta
    9
    Pics of the ladder section
  20. Back To Top    #20
    May 2016
    Bethel Ohio
    1
    How did you get the brackets on? Did you have to drill into the polls? Thank you
    Quote Originally Posted by mlunsford View Post
    Jen
