Thread: Rain and Adding Chemicals
    Oct 2011
    Kingwood, Texas
    18
    We've had a lot of rain in the last 24 hours with more on the way. This may sound really dumb, but should I still add chemicals and try to keep it balanced? I'm afraid if I wait until the rain goes away, maybe several days, the chemicals will be so out of whack that it will take forever to get them balanced!
    17,000 gal. inground pool, Diamond Brite cool blue, Kreepy Krauly Legend inground pool cleaner(w/seperate pump), Pentair Clean & Clear Plus cartridge filter (420sq.ft), Pentair IntelliFlo vs-3050 variable speed pump, Pentair Rainbow model 320 chlorine feeder, Pentair IntelliBrite 5g LED lights (2), waterfall and 32 ft. of weeping wall (w/seperate pump), 2 skimmers, 4 drains, tanning ledge w/2 geisers, Jandy EE2500TI Heat Pump
    38,262
    Re: Rain and Adding Chemicals
    The most important is to keep your FC in the appropriate range for your CYA level ... that MUST be done or stuff could start growing quickly. The other levels should be ok going a few days without adjustment.
    I see you have a chlorine feeder listed in your signature, are you still using it and are aware of its impacts on your CYA level?
