Thread: Skimmer basket access blocked by top rail
    PhillySportsFan's Avatar
    Jul 2010
    Danville, PA
    5
    Good day all,
    I must be the only one with this problem, at least I think so after doing a couple searches...
    The top rails on my pool are quite wide and blocks the skimmer enough you cannot remove the basket without reaching in the pool from the outside. Not the worst problem in the world, but annoying enough for me. Is there a replacement skimmer that extends further away from the pool to avoid this problem? If so, I can't find it.
    Any suggestions? Thanks in advance.
    21,200 Gallon 30' Round AG; 19.5" Pentair Sand Dollar w/ 1.5hp Pentair Dynamo Pump
    Installed July 15, 2010
    First purchase after ordering pool: TF-100 Test Kit
    22,542
    Re: Skimmer basket access blocked by top rail
    Do you have a wide mouth skimmer? They sit father back because of the rectangle to square transition piece.
    Jul 2010
    Danville, PA
    5
    No, it has a standard size skimmer.
    22,542
    changing it to a widemouth might solve your problem. You could also look for a throat extension for the skimmer you have.
