Results 1 to 10 of 10
Thread: CPSC36 Question
    CPSC36 Question
    Does the Compupool CPSC36 have a plug-in for your pool pump? The manual on their website states that it does but I have read some posts saying it does not. If not, what is a good external timer for running the SWG and pump?
    15' x 30' x 52" Oval AGP; 1hp Hayward Powerflo LX Pump; Hayward Sand Filter; 4 2'x20' Sungrabber Solar Panels; Compupool CPSC36 SWG
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Re: CPSC36 Question
    Hi Sturge33,
    I just looked over the instructions again and I'm not seeing where it says it's a plug-in.
    Right out of the manual:
    Input Power
    The Compu Pool CPSC/CPA Series comes with a terminated
    power cord that should be plugged directly into the external
    time clock unit. For Canadian installations: Connect to a circuit
    protected by a Class-A ground fault interrupter.
    The Keyword in the above is terminated. Don't confuse the word "plugged" as an action. It would be better to read as "that should be wired directly into the external time clock unit"
    Bonding
    A lug for bonding is attached to the bottom of the Compu-
    Pool CPSC/CPA Series enclosure. Connect to the pool bonding
    system using minimum 8 AWG copper wire if required by code.
    As for actual timers, that's going to depends on what you want. Mechanical or Electronic timer (examples shown here).
    I personally use an Intermatic mechanical timer w/ metal box. It's hardwired into my houses breaker box, then the CompuPool is hardwired into the timer box that has two connections. One is for the SWCG and the other is for my pool pump.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Re: CPSC36 Question
    OK, that makes the hookup a lot clearer than their instructions. Does your timer have a model number? Do you think this timer would work for running the swg and pump?
    http://www.1000bulbs.com/product/5226/PMC-CD105.html
    Cincinnati, OH
    424
    Re: CPSC36 Question
    I have the Intermatic T104R DPST 24 Hour Mechanical Time Switch -208-277 volt.
    Ive never heard of that brand so im not sure about reliability or longevity, but thats me
    But According to that mfg website, the CD105 is rated at 120 volts. That will require you to reswitch the compupool unit inside to accept 120 volts.
    The have a CD106 that's rated 208-227 volts.
    But either one can switch two non-isolated loads alternately.
    Eric
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Re: CPSC36 Question
    Don't you mean the CD104?
    http://www.1000bulbs.com/product/5227/PMC-CD104.html
    That's a good price.... Man, I just bought the Intermatic from Lowes last night for $69, and I just found the same timer on Amazon for $54 and free shipping.... so the one from Lowes is going back to the store, and the other will come in Friday. I wasn't going to be able to rewire it until Sunday anyway.
    Now I have to figure out what to do with my 120V Intermatic.
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Re: CPSC36 Question
    I ended up getting an Intermatic T103R. My pump is 115v so I'll have to rewire the CPSC36 when it gets here. I found some pics of it and it looks simple to do.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Re: CPSC36 Question
    It is simple to change from 230 to 115, just be sure the wires are where they should be, in my case the red/orange wire was swapped, and I had to swap them back to make them match the manual. You'll know if it's wrong, because the unit won't turn on.
    My system was wired for 115, and with a 20A breaker, it would occasionally trip after adding the SWG, even though it ramps power slowly upon power-up. I just put a dual pole breaker in my box and rewired the entire system for 230, so it should be easier on the electrical connections, wiring, & breakers. I had a main breaker for my outside box go bad on one side, and I'm guessing it's because of the pool causing more load on that one side. This box only powers the outside A/C unit and the pool pump.
    K-2006 Test kit
    Re: CPSC36 Question
    I got the CPSC36 today and I'm really impressed with the build quality of it. It's much heavier than I expected. Did you have your swg and pump on the same circuit? The unit has a sticker on the bottom that states Input Rating: 9.5 amps. Will that be too much current for a 20 amp breaker with the pump on it too?
    Re: CPSC36 Question
    The usual setup is to wire both the SWG and the pump to the same breaker. The SWG doesn't actually draw anything even close to 9.5 amps. Most likely it is somewhere between 0.5 and 2 amps. That is small enough that it almost always works out.
    Cincinnati, OH
    424
    Re: CPSC36 Question
    My pump abs SWG are wired to one 20A breaker.
    Eric
