Results 1 to 10 of 10
Thread: In the Swim Liquid Bleach
    Does anyone know anything about this new product? Is it a viable alternative to bleach?
    http://www.intheswim.com/Pool-Chemicals ... -Chlorine/
    Kurt R
    35900 gal. 20x40 Inground, Vinyl Liner with Deep End in the Middle, Roman Stairs on Both Ends
    Sta Rite Sys 3, Hayward 1.5 Super Pump, Aqua Heat Heat Pump, Paramount in Floor, BBB
    22,553
    Re: In the Swim Liquid Bleach
    It's actually 73% Cal-Hypo. Not liquid chlorine at all. Nothing different about it than Cal-hypo powder, except some fancy marketing. Trying to fake people out by saying it's liquid chlorine. It's higher priced than Cal-hypo "shock" too. $21 for 4 lbs of this or $22 for 6 lbs of Cal-Hypo "shock".
    Edit-answered my question while I was typing
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    Thanks, I figured it was some kind of marketing ploy but figured I would check with the experts at TFP
    Kurt R
    poolsupplysales's Avatar
    Jan 2012
    Tulare, CA
    112
    I have never heard of this product but if it is calhypo like you say do not use it in your vinyl pool. Calhypo disolves slow and will settle to the bottom of your pool and can damage your vinyl. Calhypo will add calcium to your pool and the calcium level should be between 200-400 ppm. Calhypo can cause cloudy water
    30,431
    Once you understand the side effects of Cal Hypo, it is fine to use........within reason. The whole idea in BBB is to understand why and when you put things in your pool and what they do (sometimes both good and bad) when you put them there.
    May 2011
    Coral Springs, FL (near Ft. Lauderdale)
    93
    Here are the details on this product: http://i.poolproducts.com/pdf/Y7700-manual.pdf
    15x30 inground concrete pool w/spa and spillover, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter and Hayward Navigator V-Flex
    Jandy AquaPure 1400, Laars LX400 propane heater w/120 gal above-ground tank
    Jandy VS FloPro 2.7 HP Pump VSFHP270JEP; FlowVis FV-C Flow Meter
    Jandy iAquaLink and OneTouch controller w/PDA remotes; JVA for draining pool
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    And to think I came up here on TFP to ask this question exactly. Thanks for the answers guys, I was chuckling as I read the description for this product in the recent "In The Swim" catalog. "Easy to use powdered chlorine [u]mixture[u]" .... hmmmm ... what do they mean by "mixture"??
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Wow they have redefined the word "Liquid" notice even their description calls it a powder.
    May 2011
    93
    Cal-hypo in a gallon jug. Isn't there an admonition in pool school against adding water to chemicals instead of adding chemicals to water?
