Results 1 to 8 of 8
Thread: Jandy VS FloPro Variable or Pentair IntelliFlo 3HP Variable
    May 2008
    Hockessin, Delaware
    48
    Need some advise on a new pump please. Pool is only 6 years old but motor needs replaced and pump needs parts also so i figured now is the perfect time for an upgrade. Currently have a whisperflow wf-28 2HP single stage uprated pump. i do have a spa. I was considering the Jandy Pump as my control panel is the JandyRS-8 with the aqualink spa control. I have no idea why my PB mixed the control panel and the pumps. I do have 2" piping. If i buy the Pentair intelliflow can i just slide the motor and assembly in to the WF-28 pump housing ? That sure would make things super easy without having to do any plumbing. Any thoughts please.
    21 X 42 freeform gunite pool w/ spa
    white plaster finish
    Jandy VS ProFlow Pump
    3 returns, 2 skimmers
    pentair DE filter
    Aquapure 1400 SWG
    Raypac 399,000 BTU Heater
    Zodiac Nature 2 Pool sanitizer (haven't used yet)
    22,548
    Re: Jandy VS FloPro Variable or Pentair IntelliFlo 3HP Vari
    I didn't think you'd be able to use the housing of a Whisperflo with the drive end of an Intelliflo, but all the part numbers are exactly the same for both pumps except the motors. Even the impellers are the same for the 3 hp units. So, I'm adjusting my thinking and I really think they would work.
    May 2008
    Hockessin, Delaware
    48
    So which do you prefer ?
    pentair DE filter
    Aquapure 1400 SWG
    22,548
    If your electric rates are greater than 20¢ per kwh I'd go with the Intelliflo, but if they're not, I'd go with a 2-speed motor for the Whisperflo..
    Jan 2012
    340
    You can do what you're talking about sliding the power end into the wet end. No difference in the wet ends. You will have to buy an intellicom unit so your controls will talk to your pump if you go with. Even at that, you don't get to take full advantage of the pump unless you have a bunch of open relays. I believe aqualink rev. O or greater is what you need to run the flopro. If it were me, I'd buy the flopro and plan on doing an iaqualink upgrade down the road so everything talks.
    25K aggregate IG, Intellipro, FNS48, Polaris 360, PG2000 fiber optic light source
    May 2008
    Hockessin, Delaware
    48
    I am now thinking of upgrading to the Jandy VS FLoPro and the Iaqualink. I have the RS model with revision MM so i believe i need the following kit.
    IQ900-RS iAqualink kit w/Older RS upgrade for all-button and one-touch units dated 2006 and older with Rev. C through MMM. IQ900-RS iAquaLink gives the freedom to control your swimming pool anytime, anywhere. Using this free application for your smart phone, you are able to control all the necessary elements of your pool system.
    IQ900-RS iAqualink kit includes iQ900 web connect device, power center replacement board and Aqualink RS firmware upgrade.
    If i do this upgrade will this give me the newest revision to run the Jandy VS and all of its features correctly ?
    pentair DE filter
    Aquapure 1400 SWG
    Jan 2012
    340
    Yes. You will also be able to control your system via ipad, iphone, and ipod.
    Mike_W's Avatar
    Aug 2011
    Orange County, California
    142
    Quote Originally Posted by GZelano
    I have an Jandy/Zodiac Iaqualink with Pentair IntelliFlo VS 11018 Pump. The Iaqualink controls the pump correctly and provides pump info (rpm and power consumption) on the Jandy PDA and Ipad.
    I got the Pentair pump because the Jandy wasn't available yet and SoCal Edision was providing a rebate on the Pentair. I'm quite happy with the setup.
    Mike
    ~17' x 34' IG pool with attached spa - 20500 gallons - Gunite with a "pebblesheen"-ish finish
    Jandy iAqualink with iPad and Jandy PDA remote - Pentair IntelliFlo VS 11018 Pump
    AquaRite SWCG - Pentair SMBW 4060 DE Filter - Really Old Raypak heater
    "Wall-E" an Arneson-Hayward Navigator - A couple of Jandy/Zodiac WaterColors LED Lights - Blue-White F-1000 Flow meter
