Thread: Shallow End - Wall Depth or Water Depth?
    Apr 2012
    Chicago, IL
    21
    We are in the final stages of working with our PB on the permit process. We've decided on a 16x30 Kidney (Polymer Wall), splurging on a couple extra features (deck jets, "beach" area).
    We do not want a deep end, but rather a flat bottom rec pool. It will be used by adults ranging in height from 5'2" to 6'2".
    I have a question regarding depth.....
    When I read forum posts are other internet postings, when someone refers to 4' depth - Are they speaking about the wall depth or actual water depth?
    We even emailed a resort in Mexico where our family has visited a couple times to gauge their pool depths. They replied 4' - but we're unsure if that is actual water or wall depth?? Is there an industry standard that when you refer to pool depth, you are referring to the water level?
    We're shooting for 4' water depth throughout - which should be comfortable for all swimmers/loungers, but don't want to get mixed up and end up 6" short.
    Thanks for the help - I'll keep everyone posted along the process!
    Doug
    16 x 32 IG Vinyl Pool. Free-form kidney with swim out beach area. Jandy Filter/Pump/Heater.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Re: Shallow End - Wall Depth or Water Depth?
    Above ground pools usually have a wall heigth of 52" or 54". The 4 foot is either to the middle of the skimmer or your normal water level.
    Nov 2011
    Moberly,MO
    1,010
    Most polymer wall panels are 42" then you will lose approximately two inches to pool base or some other base material for your liner to rest on. Then you will lose some depth to the freeboard above the water level. If you are wanting a true four feet of water you will probably want about 4' 6" of depth
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    My pool is built with 48" polymer walls and I have a 3'6" water depth. If you are going for a 4'6" depth the walls will be layed and then dug down to get you the 4'6" water depth. Make sure you are saying water depth and not wall height. I have several friends and after they built their pool no deep end. They now regret it. After being in my pool ang going down slide and on diving board they really are kicking them selves. Make sure this is what you really want. Costs too much to go back later. and lots less now.
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
