Thread: Caretaker pop-up head problems
    How does one unscrew the heads for replacement or cleaning? There is a bayonett style too that unscrews or pulls out? I don't want to break these things cleaning them. I just got the gear assembly re-built but the pop ups either don't rotate properly or dont come up and the one at the top step gushes water from it's top?? help
    Just getting started and learning a lot...
    Pacific Pool Laremont 20' x 40' approximately 28,000 Gallons
    Installed our own liner from InTheSwim, 270 measurements or so.
    Equipment: ( not sponsored by Jandy, we tried to avoid compatibility issues by buying from same vendor... stop laughing!)
    Jandy Pro Series VS FloPro 2HP Variable-Speed Pool Pump
    Jandy 1.5Hp for backup
    Jandy SFTM Top Mount 83GPM Sand Filter with ZeoBest Sand Alternative
    Jandy AquaPure 1400 Salt Water Chlorinator
    Jandy LXi250NN Heater
    Jandy iAquaLink control system
    South Central NJ
    3,192
    Re: Caretaker pop-up head problems
    There is a circular wrench for the heads. It has two fingers that fit inside and a little deeper. Up they come.
    Scott
    Owner of - PoolGuyNJ LLC
