Thread: Water supply line to above ground pool
    Jun 2010
    NE Oklahoma
    40
    We received the new filter and pump. Now we would like to run a water supply line from the outdoor faucet to the pool using PVC. Can anyone give me some direction on how to do this? Thank you in advance for your help.
    16 x 32 x 54" AG buried 2', Hayward S244T Sand Filter, Hayward 15922S Power Flo Matrix pump
    22,543
    Re: Water supply line to above ground pool
    If you can post a pic of the equip pad we can provide better info but you can hook the water line anywhere in the pool plumbing but be sure to install a [s:2hqjimvo]check valve[/s:2hqjimvo] Back Flow Preventer in the water line.
    Nov 2011
    Moberly,MO
    1,010
    You need to check with your water provider you may need a backflow preventer installed inline.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    22,543
    When I said check valve I meant Back Flow Preventer. Which is actually a double check valve and a vent.
