Thread: Booster Pump powered squirt guns? Or return powered....
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What would be the concerns? You'd need a manifold to enable several hoses(guns) or at the minimum a three way tee. I imagine you'd need a way for water to be going into the pool when guns not in use to avoid damage to pump. Maybe easiest to accomplish at the guns, when you pull trigger you are narrowing the hole the water comes through, or diverting it's path to gun nozzle. Then you'd want to be sure you don't damage the Polaris connection point in pools side. Don't want to get tangled up in hoses.
    Maybe poolside mounted turrets would be better, like the air powered ones that shoot Nurf balls at kids play places?
    Maybe just stick with super soakers?
    I guess if you used one return and you had another one or two you might be less concerned about pump damage?
    Might be Easiest to alter a squirt gun, attaching pressure hose to it's tank?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Booster Pump powered squirt guns? Or return powered....
    Do you plan on cap'n someone right in the ear?
    Or how about an eye?
    Painful...
    With the proper sized orifice, you'd probably be able to disable anyone in the pool area.
    Factory Warranty Station for:
    Mar 2011
    Sunny Central Florida
    91
    My kids have a pvc sprinkler that they put in front of a return to shoot at each other.
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
