Thread: Fire Magic advice, should I get a sear burner??
    Hello all,
    Great forum and very informative. I am going to order a new Fire Magic Echelon 36" model on cart. It has 3 main burners (75,000 btu's), 1 IR rotis burner and a smoker burner. I can switch out one of the main burners for an IR burner for FREE. I am on the fence as too whether get the sear burner. Any Fire Magic owners or anyone with an IR sear burner out there that perhaps could shed some light on how well the sear burner works? How well does this bbq sear without IR? The burner does take up 1/3 of the real estate of the grill. I am told this grill gets plenty hot to sear without an IR burner. If I get the IR burner will I sacrifice even heat distribution not having the 3rd regular burner? (it does have zone divider plates) will the side with the IR burner create a cold spot?. Is the burner adjustable for heat, what temperature range does it have? To sear or not to sear??? I do cook plenty of steak, chicken, fish, veggies and regular burger fare. Any advice or opinions please.
    THX
    Re: Fire Magic advice, should I get a sear burner??
    I do not have that grill but I am building a new outdoor kitchen and the grill I have has a side sear burner. I would not function without it for
    Steaks or chicken. I sear every steak and it is amazing how much it locks in the flavor and juices. It sounds like the grill you are looking at is a good quality one and if the temps can be achieved by the normal burner then the results should be the same. But you bring up some good questions about the even heat and cold spots. I am not sure as mine is separate from the grill.
    I probably would not use it on fish or much else but for steaks and chicken it's a must have in my book..
    Wish I could add more.
    17500 gallon inground vinyl liner kidney shaped pool
    2 hp Hayward SuperPump, utopia filter system(fabric bags 6,15,30 micron)
    Hayward H-series 150 heater, Fiber Works fiber optic pool light.
    And the knowledge from everyone here at TFP.
    St Marys, WV
    Thanks for your input. I decided not to get the sear burner for now. I could add/ retrofit it later or even put in a side IR burner later.
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    I just ordered a Fire Magic and spoke to the owner and the temp that the std burner get to is more that enough to sear. This is not your std cheep grill or weber. the burners for the E790 are 25000btu each.
    How is your new grill?
    22x52 IG 56K gal 3.6' to 11.6' deep, TruTile w/Vinyl Liner IG pool w/ 12" wide safety ledge
    StaRite System 3 Cartridge filter 450sqft S8M450, Pentair IntelliFlo VF pump 3.2KW
    Hydronic in floor heat & StaRite SR400HD, Pro Logic PS16 w/2 40K Turbo cells.
    4 Hayward Colorlogic lights, Dolphin DL3002 Robotic cleaner
    Saint Charles, IL
    Quote Originally Posted by divepool
    Grill is great. Main burners register at around 975 deg on full after 10 min. The zone dividers work well to keep the heat separated. Rotis is a little noisy. there's a learning curve to Low heat cooking and smoking and take some time to adjust the right balance. Haven't tried the side burner since the electrode came broken and I am waiting for a replacement.
    divepool's Avatar
    Aug 2008
    St. Charles IL
    37
    Glad to hear that you like it. I was looking at Lynx and Fire Magic. Fire Magic has the better warranty and no ceramic brickets to replace. Can't wait to get it and use it. I have never used a side burner on any grill I have ever bought. Time will tell if I use this one. 975deg is hot, sear anything.
    Rich
    Saint Charles, IL
