Removed the winter pool cover the other day, to sparkling clean water! Without adding any chemicals, these were my numbers:
FC - 4.4
CC - 0.6
PH - 7.7
TA - 170 (need to aerate)
CYA - 100
CH - 200
Water temp - 53 F
Test kit is a Taylor - K-2006
My question is this: I was a little unsure about my CYA testing, and think I may have added too many drops to get the black dot
to disappear, and not sure the last several drops did anything at all. With my numbers as they are, especially the FC number, is
it even possible that my CYA number is 100? Seems like if it was this high, my FC would have been around zero. Or, is it possible
that the colder water temps affected my readings?
FC - 4.4
CC - 0.6
PH - 7.7
CYA - 100
CH - 200
Water temp - 53 F
