Thread: Block pool with underwater room and window
    Hello i am new to this but i need some help with my project. I am designing a concrete and block pool with and underground room on one side with a window looking into the pool in it. i have done a lot of research on this type of pool building but i was wondering if anyone has atempted this kind of thing and if they had any tips or suggestions before i get started. i have put a picture so you can kind of get the basics of my plan.thank you.
    9400 Gallon Above Ground, Vinyl Liner, 20 foot round, 4 feet deep 2 filter cartidges one Type B in the skimmer, and a C-50 hayward in the big box, 1/2 Horsepower Dynaflo Pump. TF100 Test Kit, well water, clean with Iron used for filling (CH of fill water is 450).
    22,553
    Re: Block pool with underwater room and window
    That looks interesting, just be sure to allow for plenty of air circulation through the underground room.
    yeah it will be open on both sides it will have a staircase on bosth sides going up to the pool deck, i have read that you should not use mortar joints in between the block on the outside of the pool, why would this be an issue it seems that if you do not have a bed joint that the block will be unstable when you go to pour the block for the pool.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi meatball and welcome to the forum
    I saw an episode on HGTV where folks had an underground viewing room to their pool.....fascinating and lotsa $$
    Please post lots of pics
    You're done SLAMing when:
    Things like this always have people ask .... Why? To then be rightly proceeded by the comment ..... Because I can! )
    Enjoy!
