Results 1 to 8 of 8
Thread: Expansion Joints in concrete around pool?
    Mar 2008
    Muskogee, OKLAHOMA
    35
    I would gladly like to have suggestions on what type of expansion joints everyone is using around pools. Ours is in the process! They dug hole on Tuesday and set in yesterday! We are putting in a San Juan pool here in Oklahoma. 19 x 35 Diving pool.
    And any information you care to share would be great!
    Thanks!
    Summersgal
    San Juan American Inground Fiberglass, 22K cap, Hayward 1 1/2Hp Super 2Pump, Hayward SwimClear Cartridge Filter, Diving Board, Slide. Dedicated suction line for "The pool cleaner that is due tomorrow!
    30,403
    Hi, Summersgal,
    Not sure exactly what you're asking. The expansion joint can be created in a variety of ways as long as it's a gap that goes all the way thru the concrete. It is usually filled (on top) with polyurethane caulk for waterproofing and appearance.
    I have a feeling you already know that and are asking something else. Could you clarify?
    Mar 2008
    Muskogee, OKLAHOMA
    35
    Hi Dave
    Thanks for your reply! I guess I didn't make my self clear...thats usual for me!
    I'm wanting to know what is the best thing to use to make the expansion joints. On our old pool from our previous house we used cedar and it bowed up. So my Hubby said to ask and see what people use and what luck they have had with what they are using and to try to find out what is avaiable out there. Hope this is a better way of trying to explain myself.
    Jan 2008
    Forney, TX
    162
    You definitely do not want to do redwood strips around a pool. Typically with pool expansion joints a foam insert is installed that has a perforated section about an inch from the top. After the decking is poured, the upper section of the foam is pulled off at the perforations and the remaining joint is sealed with mastic. While the mastic is still wet some granules are sprinkled on it to give it a texture and provide more durability to foot traffic. It also helps it to blend in to the decking a little better. I'm not sure what the industry standard is on pool deck joints, but in sidewalk paving it's normally 5' o.c. for control joints and 20' o.c. for expansion joints.
    Also, if any of the pool decking is adjacent to existing paving be sure to dowel it in.
    Our pool adventure... click here
    Mar 2008
    Muskogee, OKLAHOMA
    35
    TresW
    Thanks for the reply Do you have or know the name of the foam inserts that you are talking about and where you got them? Or where we might be able to get them?
    Thanks!
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Here's a little more info on mastic
    http://poolmastic.com/whatis.htm
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Jan 2008
    Forney, TX
    162
    Quote Originally Posted by Summersgal
    TresW
    Thanks!
    Ours was installed by our PB, but it is the same stuff as this:
    http://www.reflectixinc.com/diy/default ... eIndex=546
    You might call those guys and see if they have a rep that is local to you. I'm sure there are other manufacturers as well. Good luck!
    Mar 2008
    Muskogee, OKLAHOMA
    35
    Thanks again! The company that did our pool do not do the concrete work and se we are planning on doing all the forming of the job and then have someone come in and do the finishing of the concrete. We just finished our house last year which we built almost the entire house. But the pool area is different and just trying to make sure we have ideas before we start and find out what the latest things are that are out there. Pool finished filling yesterday and nasty!
    Another question..Tips on keeping the concrete off the side of pool while pouring the concrete?
    Thanks gain everyone for all the tips and info!
    I love this site..lots of information and help!
