Thread: Can cool decking be stained?
    Mar 2012
    Northern California
    59
    I have a 28 year old pool with a lot of cool decking around it. The cool decking is in really good shape, it's just ugly. It's kind of a pinkish or salmon color that has faded. We would like to stain it a darker color, or at the very least clean it really good. Can cool deck be stained and if it can what is the process? Second, if it can't be stained darker, can I acid wash it or something else to try and bring it back to life? Thanks for any input.
    32,000 Gallon Plaster Pool
    Hayward Aqua Plus 40k Gallon Chlorine Generator w/ Controls PL-PLUS
    Pentair IntelliFlo Variable Speed Pump
    Polaris 3900 Sport Automatic Pool Cleaner
    Polaris 3/4 hp Booster Pump
    Pentair/PacFab Nautilus D.E. Filter 48 Sq Ft
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Can cool decking be stained?
    An acrylic deck top-coat can be put right over Kool Deck. You would loose some of the cooling effect of the Kool Deck material but you end up with the better durability and greater stain resistance of an acrylic deck (which I actually prefer). You can chose any color top-coat you want. The Kool Deck will act as the texture coat. I have done this and it worked quite well.
    chiefwej
    Aug 2007
    near the swamp
    806
    Yes, clean it then roll on the color of your choice in 2 coats.
