Thread: Glass in pool, reopening.
    Feb 2012
    Stowe, VT
    59
    Hey everybody, wondering if I could get some solid advice on removing glass from the pool. A guest at where I work decided to sneak glass in and of course accidently dropped it and it shattered all over the pool deck and quite a bit of it ended up in the pool. Currently my boss asked for a drain which it is currently undergoing. The pool is underground and gunite.
    Then skipping way ahead. My fill water tests at
    FC = 0
    Alk = 70
    pH = 8.2
    Cal hardness = 50
    Should I add any chemical/chlorine while it's filling or just wait? It's going to take about 2 days to fill completely and there's plenty of pressure to re-open it of course.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Glass in pool, reopening.
    You can put in some bleach. MA after it's full.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Really no need to drain. The glass can be vacuumed out using a side pump, or through the system using a Vac plate over the skimmer basket with a skimmer sock in the basket to catch the glass pieces.
    Once you have vacuumed and brushed a few times, there should not be any glass left in the pool.
    Support the site
    Feb 2008
    Denton, TX
    5,061
    Considering the length of time that it will take to fill completely, I would keep a residual of FC in there during the process.
    30,403
    That doesn't sound optional to me. I hope you are draining the pool.
