Results 1 to 10 of 10
Thread: Question abut pool size
    Mar 2010
    Spring, TX
    1,082
    Every since we have been in our home I have been trying to figure out the size of our pool. When I did the initial measurements I came up with 22000, but everytime I would use 22000 as the size and put in my figures in the pool calculator I would add what it would say. Then I would test and it went over. So lately I have been using 20000 gallons as the size.
    For instance tonight my FC was 3 and I wanted to raise it to 5. So based off of 20000 gallons to go from 3 to 5 you need to add 83 oz. So I just put in 80 since what I use to measure my bleach is in increments of 8 oz. So that was about 2 hours ago I added the chlorine. So I rechecked to see what my FC level is and it went from 3 to 7.5. If I adust the gallon size to 8600, I get my starting point of 3 and goal of 7.5 at 80 oz of bleach. Am I doing something wrong or what. I have measured my pool several times and I always get the same amount around 20-22K.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Question abut pool size
    Are you plugging in the correct bleach %-as in 6%?
    What are the dimensions and depth of the pool?
    Support the site
    38,516
    Or you may just have gotten a good batch of extra strong bleach .... can't imagine you are off by 10,000 gallons.
    Posted with Tapatalk 2
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by woodyp
    Yes.
    Mar 2010
    Spring, TX
    1,082
    Quote Originally Posted by JamesW
    It is a very hard one to measure due to the odd size. I get about 27 feet long, and around 11-14 wide and 3 shallow-6 ft deep.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You may do better to measure it in segments, find the gallons for each segment, and the add up the gallons.
    Love TFP? Become a
    TFP Supporter!
    Your pool is probably around 12,000 to 13,000 gallons.
    Support the site
    Butterfly's Avatar
    South Carolina
    10,045
    Using the PoolCalculator & your numbers, I am also getting a much smaller pool volume.
    You're done SLAMing when:
    Quote Originally Posted by mynewpool
    How did you get 22,000 gallons?
    Support the site
