Results 1 to 1 of 1
Thread: Do I have a pump relay on my Autopilot DIG-220? [PICTURE]
    Apr 2011
    The Bluegrass State
    61
    Opened the pool today and everything with off without a hitch (thank you TFP), so naturally I NEED to find something to work on. My pool was installed with the pump controlled by a normal on/off switch inside a box next to my Autopilot. I have no idea why the Autopilot isn't controlling it but apparently the pump relay (part #AK0004) is NOT included with every Autopilot. At any rate, I want the Autopilot to control my pump so I can run it less than 24 hours a day.
    I went out and popped the cover off it and then the metal cage beneath it and snapped this pic below. I don't know what I'm looking for so I'm hoping one of you pros here can look at the picture and tell me if I have this pump relay or not. I found one online for $23 so I went ahead and ordered it just in case I don't but I'd be more than happy to stick it in a drawer as a backup if my Autopilot already has it.
    On to the pic (which is also attached to this post if the one below isn't large enough)...
    1. Do you see a pump relay in this picture?
    2. If not, and I use the one I ordered, does it mount anywhere in particular in this mess of wires or is it just "hanging out"?
    Thanks!
    All I know about my pool at this point:
    Size: 17,000 Gallons - Oval
    Type: Inground - Vinyl - Salt Water
    Filter: Sand
    Controller: Autopilot
    Pump: 1HP Waterway Mustang - Single Speed (MUSTS-110)
    Heater: Aquacal Heat Wave
    Robot: Barracuda G4
