Thread: TA while treating algae
    Sep 2010
    Roatan - Bay Islands
    35
    OK after almost 2 years of trouble free pool, thanks to BBB, I am now fighting some algae (my liquid chlorine supplier has gotten me without product for more than two weeks now).
    I am currently shocking my pool at 26 FC and have been running my pump for almost 48 hours. Pool finally turned from green to blueish and it's starting to clear up. My TA level is 20 (took the reading before starting the shock process) . Should I add baking soda now or wait until the process is finished and my chlorine level is back to normal?
    By the way, for as much as I wanted to avoid using nothing but chlorine, I had to use cal-hypo 65% for the shock, my supply of chlorine is not yet ready to be delivered.
    P_
    _________________
    10,000 glns bean shaped inground plaster pool - Pentair SD60 sand filter - Pentair 3/4 HP pump
    Re: TA while treating algae
    Yes, with TA that low you should raise it. I suggest raising TA to say 60 for now, and waiting to do any further increase until you are doing fighting algae. With TA down around 20, the PH will swing around far too wildly with every chlorine addition, most likely going out of range with the attendant risks. Raising TA now will help minimize and/or prevent that.
    Sep 2010
    35
    Thanks Jason, I just raised the TA to 60 and now after 3 days of continuous pump my pool is almost clear. TA is in check , PH as well, FC is obviously still high at about 25. What would be a safe FC value for letting the kids jump back into the pool? Tomorrow morning they ll see the pool sparkling blue and it will be difficult to convince them they cannot!!!
    P_
    _________________
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by pakalrtb
    P_
    If the FC is below normal shock level for your CYA, CC is .5 or less and the water is clear, it's okay to swim.
    You're done SLAMing when:
