Thread: Intex pool foam instalation ?s
    poolnew-b's Avatar
    Jul 2010
    laconia, NH
    131
    Hi again all,
    I will be taking down my Intex pool and re-leveling and I figured I would throw some foam under it.
    What thickness should I use and should I put blocks under the legs? Ive seen a post or 2 talking about not using blocks and not having any problems with the legs being on the foam.
    Intex Ultra frame 16x48
    Intex 1600GPH Sand Filter
    Taylor K-2005 test kit
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Intex pool foam instalation ?s
    Quote Originally Posted by poolnew-b
    I can't answer you questions with direct experience. Take a look at this link:http://www.troublefreepool.com/foam-...me-t42304.html
    From the discussion in that link, and if I was planning on taking the pool down each winter, I think I would try extruded polystyrene all the way under legs and all taped with gorilla tape.
