Results 1 to 10 of 10
Thread: Pentair FNS plus has a small leak. Any ideas?
    Hi All,
    I have a Pentair FNS plus 48 DE filter. It has a small leak around the separation between the upper and lower tank. I replaced the large o-ring last year. Any ideas how to stop it. IIRC I had the same leak last year but it wasn't nearly as bad. It was very slow. Even now it just seeps out but it annoying. I don't want to buy another o-ring if it could be another problem. Also I installed the o-ring dry. I didn't use any teflon lube. I'm not sure if that's correct or not.
    Thanks for the help,
    Joe
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    38,463
    Re: Pentair FNS plus has a small leak. Any ideas?
    If it is like my Hayward, you are supposed to lube it up good when you install it. That is the likely cause of your leak. And should be a pretty cheap fix
    22,553
    I agree you should lube it well. That large an o-ring needs to 'settle' into place and without lube it can't do that.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Lube the O-ring and adjust the band clamp and re-torque.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    38,463
    I also want to add that when I am tightening the band clamp I get it snug and then tap on it all the way around with a rubber mallet to seat the band some more. Then tighten and tap, tighten and tap, etc until the bolt/nut stays torqued to the correct spec after tapping.
    Thanks for the tips. Is there a torque value for the nut. I didn't see one listed in the manual.
    38,463
    On my Hayward you tighten until a spring is compressed and touching ... not sure about the Pentairs.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    It says to compress the spring until the coils touch each other.
    meh, I did all of the above and still have some seepage. Any other ideas?
    Quote Originally Posted by cruzmisl
    How much lube did you use?
    This year when putting everything together, I cleaned all of the connecting surfaces of both tanks, and the o-ring. I put it back together forgetting to lube it up and it was leaking.
    I took it apart, lubed up the o-ring real well and put it back together. Still leaking!
    So I took it apart again and lubed the ring again, plus the lips on the top and lower tank. Put it back together, no more leaks.
    It can take a lot of lube, especially if you are starting with None. My o-ring seems to absorb a lot of this stuff.
    Also, I use something called o-ring lube that my pool supply store stocks, its nasty green stuff, but made specially for this application.
    16,000 gal in-ground
    Pump: Hayward C48K2N143 1HP 230V
    Filter: DE Triton Nautilus FNS-36
