Results 1 to 7 of 7
Thread: Getting Alkalinity down quickly
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    I tested my water yesterday and TA was 140. I dropped pH to 7.0. Today TA was down to 125 and pH 7.4. I can't aerate right now. To cold to swim and I don't have a fountain. It might rain in the next day or so, so I can remove the solar cover.
    So am I on the right track? Can we swim this weekend with the TA up if pH is ok?
    Looking to get in for the first time on Sunday.
    My numbers:
    FC 9
    pH 7.2
    TA 125
    CH 310
    CYA 70
    Salt 3500
    Borates 30
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    38,537
    Re: Getting Alkalinity down quickly
    From my understanding, TA has basically no bearing on whether the water is safe to swim in or not. It is a pH buffer.
    If the Ph and FC are good and the water is warm enough ... have fun
    30,432
    Ditto what Jason said. Go swimming. Also, leave your TA where it is unless you have some pH problems.
    Apr 2010
    Coral Gables, FL
    197
    Huh? I thought it was too high? Thats according to the Pool School chart for SWG balance.
    Adjust your Total Alkalinity to 60-80 ppm. (This is IMPORTANT!)
    To summarize:
    FC 3-5 ppm
    PH 7.5-7.8
    TA 60-80
    CH
    50-300 for vinyl
    220-320 for fiberglass
    250-350 for plaster
    CYA 70-80
    Salt 200-400 ppm ABOVE recommended optimum level
    Borates 30-50 ppm (optional)
    30,432
    It's higher than we suggest but it won't hurt you (unless your pH becomes unstable) and you seem to be impatient so just leave it alone. The information and suggested guidelines we provide are just that....suggested. Particularly with TA, you may never notice a difference.
    Apr 2010
    Coral Gables, FL
    197
    LOL! I can be at times .
    I have hd excellent water side joining here 99.9% of the time. This winter I got lazy. So the higher TA is not going to "hurt" the pool right now?
    I will just keep working at it, until its in the recommended range.
    The Pool store also said it was high and to take my time getting it down with acid.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by Hurricane Gio
    Nope, you might experience a fairly constant ph rise (probably slow), but if you do, the good news is that the acid needed to bring the ph down will also slowly lower the TA. Just make sure you keep an a little closer eye on your ph. Just a note: since you have borates, getting TA down may take awhile longer than if you had no borates.
    Is rare, but the pool store is right this time.
