Thread: questons about light
    when the pool company installed my liner and put the light in they told me it may lead due to something about the screws and the housing. they came an checked it for several day and told me it was leaking out around .5 inch a day. after about a week when i turn the light on, the gfc breaker trips. they finally came back to deal with the light leaking and took it out even though the water level is above the light housing. they just left the light on top of the deck and left with out saying anything. I assume they are needing a part or something so they must be waiting for it. anyway, since the light is now on the deck i figure the light will now work. but it does not, it still trips. any idea what may be going on. it is a color logic hayward light. thanks.
    22,553
    Re: questons about light
    There's an issue with the light itself and it needs to be brought to the attention of the installer. The leak they're working on is in the niche and really has nothing to do with the light not working.
    24' x 52" Round AGP. 2hp/╝hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Nov 2010
    Calera, Al
    271
    I may be mistaken, but I do not think it is good to turn on the light when it is out of the water...
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    I that is my point. I am trying to determine who to contact, the person who installed the liner or the electrician who did the wiring. ┬*The light worked for 2 weeks. Then it just started tripping the GFC. I assumed it was due to water leaking into the housing. My thinking was that now the housing is out of the water, it should now come on without tripping the breaker. ┬*It comes on for a second ┬* then trips the breaker. The light is sealed in the back, right? ┬*Therefore, water should not be able to get into it. Is that right. As it is now the light is on the deck sitting there but the housing with the cord is running from the light though the under water housing to under ground conduit to the junction box . ┬* ┬*Also, this light is a new one just installed when the liner was put in. ┬*Thanks for any help you can offer guys.
    22,553
    I'd call the electrician. Even if it's in the light canister, she (or he) will have to disconnect it and pull it out to send it out for repair.
    Guys got it working. I called the electricion. When he took the junction box off it had water in it. Also, were is is a junction box from the GFI to the light to to pump/salt that had water in it too. We figure that when the light leaked the water traveld through the conduit. We sucked it out and put silicone in the coduit holes. hopetully the light is not leaking anymore anyway.
