Thread: Changing Filter Sand
    Hi,
    I'm about to change the sand in my filter (Hayward S210T Pro Series 21"). First time I've ever done it. The old sand is out now, so there's no going back.
    The owners manual, and other guides I have read, stress the importance of covering the 'under-drain' stand-pipe and keeping the entire lateral assembly centered and firmly on the filter vessel base when adding the sand. An accessory 'sand shield' (SX202S) is provided with new filters to assist this.
    From older manuals, it looks like the shield was originally in the form of a dish that fitted into neck of the filter vessel, with slots to let the sand through and a central cap to cover and center the stand-pipe. Don't what it was made of. I assume plastic.
    With newer models, this appears to have been replaced by a fold-out piece of corrugated cardboard. From the illustrations, the original type does look more secure to me.
    My filter is second hand and unfortunately the previous owner did not retain the 'sand shield' or can recall what type it was.
    I did inquire at a local pool store. They said, just put some tape over stand-pipe (to keep sand out) and, if your not experienced at it (yeah, right), have one person hold the stand-pipe in place while another adds the sand.
    I need to do this tomorrow and with no-one to assist. Does anyone have any tips, tricks or DIY alternatives for keeping the stand-pipe/lateral assembly in place? I'd hate to have to start all over again because it shifted or lifted up.
    Cheers.
    PS - I know it's best to partially fill with water before adding the sand so as to avoid damaging the laterals.
    "Inherited" Cornelius 18'x54" Round AGP (Steel walls), Hayward Pro Series 21" Sand Filter, ClubPro (Jacuzzi) 1HP single speed pump, Lumi-O Festiva steps, Toile-Soleil mesh leaf net/winter cover. That's about it.
    Apr 2011
    Lynchburg VA
    393
    Re: Changing Filter Sand
    I covered the top of mine with a cup and had the wife hold it in the center while I poured the sand in the filter. Once I got the first couple of bags in it seemed to pretty much stay centered on its own.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    If you set things up so everything is right at hand, you can hold it in place with one hand, while scooping in sand with the other hand. That takes a while, but works reliably.
    I was thinking of maybe cutting up a tupper-ware/zip-lock bowl, but could find nothing to hand that fits. Anyway, it's probably better to be able to peer in and see where you are up to. Like you say, once there is some weight of sand over the laterals, it should stay put. The pool store guy did actually tell me not to bother putting some water in first, as long as you are careful adding the sand. I dunno - it does seem a reasonable precaution to me, and would surely help getting sand inside the lateral base support.
    So, yes, have everything to hand. I've got 4 x 50lb bags of sand as per the specs. Not sure how much it will take to cover the laterals - 1-1/2 bags ? I think I have some large gardening pots that would take that. Put it on a work-mate bench, chair or something right next to the filter. Maybe a torch to hand also. And put the dog inside......the house, that is.
    I'll see how I get on. What, me, worry?
    PS - One other thing that I did fortunately think about in advance, is that the new sand first has to be back-washed and rinsed to get rid of the fine silt. Right now the un-opened pool is riddled with pollen flowers and seeds from nearby maple and birch trees. Not really the type of stuff you'd want to dump inside the laterals on the first back-wash, and, with the pool getting murkier every day, the prospect of attempting to shock and clean-up first without engaging the filter bed (drain and re-cycle only) seemed remote. I'd read about these skimmer-socks and how good they are at retaining pollen, but none of the local pool stores stock them. Thanks to the TFP member who recommended using elasticated nylon-mesh paint strainers (1 gallon) as an alternative.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by WorBry
    It doesn't take much to cover the laterals, they are right at the bottom. I would guess 1/2 a bag. I use a 1.5" black rubber hose cap to cover my vertical pipe opening to prevent sand from going down the pipe (which will happen if you don't cover it with something). Then as I fill with sand I check to make sure the pipe is centered. Early on in the adding of the sand I check that the vertical is still centered at the top of the filter and make any necessary adjustments being careful to not lift (I actually push down slightly) while centering. After ~1/3 of the sand is in a centered tube won't move anymore unless you push on it fairly hard.
    You'll be fine, just take your time. Worst case, you have to take it back out and do it over...but I think that is unlikely.
    Thanks. Yeah, I do kind of make it sound like I'm going to be manipulating rods in a nuclear reactor....OK, I'm going in.
