Results 1 to 8 of 8
Thread: Any tricks to measuring CYA?
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    Its the one test I have trouble with. Like how far should the dot disapear. Test outside in sunlight? Inside?
    Thoughts?
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Any tricks to measuring CYA?
    Letting the water get to room temperature helps. But since your in FL that's probably not a problem. I do the at the waste line hold the vile and look down the tube, when the dot is completely gone that's your CYA amount.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    38,295
    Here is Jason's Extended testing direction on CYA:
    extended-test-kit-directions-t25081.html#p206397
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Not sure if you have read this yet? http://www.troublefreepool.com/exten...1.html#p206397 There is a link in there to a picture on the Taylor page that shows what the dot should look like when gone.
    Edit: jbliz beat me
    22,550
    I think the best thing to do is order some 50 ppm standard and use that to fine tune your testing. That way you can find out what dofferent lighting levels, etc does to your judgement.
    Apr 2010
    Coral Gables, FL
    197
    Where?
    TF TestKits carries it, as do a number of other Internet vendors.
    Apr 2010
    Coral Gables, FL
    197
    great, love this site!
