Results 1 to 13 of 13
Thread: Pump keeps Alarming out!
    Hello!
    Yesterday I noticed that the Intelliflow pump kept alarming out for a blockage. I checked all the baskets and everything is good. The pump has been running fine since last Wednesday. If the pump restarts on it's own (after 2 mins) it will do the same thing...alarm out, restart, alarm out.....
    but....If I reset it and start it in higher speed it will continue to run. It seems to alarm out at the lower speeds (1100-1300 rpm)
    Does anyone have any ideas? This is my first year opening the pool myself and really do not want to call on the pool company. And I am no expert on pool pumps!
    Thanks for any advice!
    28,000 IG Free Form Gunite with quartz finish
    Pentair Quad DE filter, Intelliflo VS+SVRS
    Polaris 280, Sta-Rite 400K Heater-Propane
    22,551
    Re: Pump keeps Alarming out!
    What is the filter pressure now compared to what it is clean? You need to run at the same speed to get comparable numbers.
    Have you cleaned the filter lately?
    We just opened the pool last Wednesday(the 5th). Pool was clear so I don't suspect a dirty filter already...
    22,551
    It could be dirtier than you think. Especially since it's a DE filter.
    How does the flow out of the return(s) feel compared to laast year?
    After 7 days? The pool was clear when we opened and the psi has only risen 5 pounds.... opening psi was 13 and @2800 rpm it is @18 psi
    When the pump is running @1100 rpms....the psi is 11
    Last year I only cleaned the filter once duing July. We opened in April and closed in October.
    The flow out of the returns feels the same as last year as well...
    I could clean the filter but just seems like a waste....any other suggestions?
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by mamasproject
    Even though you have only had your pool open 7 days this year, the filter could also have build-up from July-October (if I understand correctly).
    I agree with Bama and suggest cleaning the filter. It won't hurt to try...
    38,394
    Current recommendations are backwashing when the pressure goes up 20-25% of your clean pressure to maintain good flow through the filter. If your clean pressure is 13psi, we would recommend backwashing at around 16psi.
    Not sure if this is the cause of your pump alarm though.
    Okay so a dirty filter is not the answer I was expecting. If I understand the Inteliflo manual correctly...the alarm goes off because of a blockage... that would that be from the pipes coming from the pool.....not a dirty filter? And the alarm is only going off during low rpms. It runs fine during higher rpm times.
    The filter manual says to clean the filter when the psi rises 10 psi above the starting psi... I think cleaning the filter because of a 5 psi rise will be a waste of water and DE.....just my thoughts, which probably are wrong, but makes sense to me. I will have to do some more research and see how it goes.....thanks for the input!
    Nov 2010
    Calera, Al
    271
    You can do what you want... But you have received sound advice! It does make it difficult to help if you do not want to follow the advice offered to the questions you ask. The filter is the most probably the cause based on the information you have provided... De filters filter very efficiently and can quickly collect debris.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    38,394
    Granted not helping your original questions so stop reading now is you don't care about baskwashing logic
    Would you agree that a 10psi rise over a clean pressure of 10psi (100% increase) is probably a bigger flow impact than a 10psi rise over a clean pressure of 30psi (33% increase)? Without know a starting pressure (which is a function of each pool, plumbing , and pump), how can the filter manufacturer say 10psi is the number? A percentage can at least be applied generally not knowing specifics of each setup ... the 25% just comes from the resident experts here (not me) ... which could improve your circulation and filtration, although at the expense of water and DE.
    Quote Originally Posted by ROB N
    I was looking for a more technical answer since everyone on TFP has a wealth of information to give. I never indicated that I would not follow the advice given. But often I have been told that I am "difficult"....LOL
    Nov 2010
    Calera, Al
    271
    It could be one of the simplest things such as cleaning the filter or making sure you don't have debris in the skimmer and pump baskets... Let's just try something simple Before we go doing something technical or more difficult.
    22,551
    I certainly don't mind you being a little difficult. I'm a little difficult myself sometimes.
    OK, So I've gone back and read the manual.
    If the unit is indicating "Blocked System" it can either be a suction blockage or a discharge blockage. I was thinking a discharge blockage and I still think the filter's a contributing factor and you may also have another return blocakge. However, You may also have a partial suction blockage.
    How long, after you start it the first time, does it run before it shuts down and gives you the alarm?
    Have you tried running water from a hose back toward the skimmer to make sure something didn't get dropped or sucked into the skimmer partially blocking the suction?
