Thread: Repair a crack in skimmer?
    Mar 2012
    Columbus, Ohio
    16
    How can I repair a 3" long crack in the side of the skimmer box (AGP) now that there is water in it?
    24' above ground, 2008 Esther Williams, 13,500 gallon, 200# sand filter, 1.5hp pump, bottom drains.
    Mar 2012
    Columbus, Ohio
    16
    Re: Repair a crack in skimmer?
    It is a minor leak only dripping twice a minute. Is there any kind of PVC patch that I can glue on the outside?
    22,551
    Search for pool epoxy and you can apply it underwater.
    38,305
    I just had a thought ... anyone ever try Eternabond tape? It is typically used on roofs but it is some crazy sticky stuff ... could actually work in this case for a minor leak.
    {EDIT: In fact, I would be willing to mail you a piece if you posted some before and after pictures. Be forewarned, if it does not seal completely, it will be a pain in the you know what to remove it.
    Might work even better to just lower the water level below the skimmer for any repair to choose though}
    Jan 2011
    153
    You can try a 2 part pool epoxy it's called pool putty and looks like playdough.. I have put many temp repairs on skimmer using pool putty...
    JoshU's Avatar
    New Orleans, LA
    543
    +1 for the Pool Putty from Atlas Minerals
    Replacing the skimmer itself should also be pretty cheap if you want to do it yourself.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
