Thread: Help .. Year 2
    Help .. Year 2
    First off thanks for the advice on my pool liner lifting off wall. As far as I can see it is back in place. Only problem is still cloudy and can't see the bottom in deep end.
    Have been sweeping daily. Vaccum used today. Pump on 24/7 x last 3 days. Have held FC near 20 for 3 days with clorox.
    Numbers as of 5 minutes ago.
    FC 19.5
    CC 0
    TC 19.5
    pH 7.2
    TA 80
    CH ?? ** Only turned pinkish, after 50 drops it did not turn blue but did clear
    CYA 60
    My concern is the amount of leaves debris that may be in deep end. Could this be the source of my problem or should it clear even if alot of debris remains?
    Thanks
    Pat
    IG-vinyl liner, 39,000 gallons, Hayward 1 1/2 hp super pump, Sand filter (not sure on flow)
    Locale - NE Texas
    30,426
    Re: Help .. Year 2
    It's a legitimate concern and there is no easy answer. The debris consumes chlorine which could otherwise be used more effectively.
    Manually get out all debris that you possibly can. It's a hassle and you won't get it all. I invested in a pricey ($140) leaf rake which helps me when I have a mess.
