Thread: salt chlorinator
    salt chlorinator
    will a salt chlorinator work with no flow switch installed? Hayward Aqua Rite
    38,281
    Re: salt chlorinator
    It is certainly possible, you would be running a risk of it generating FC when there was no flow which could have negative consequences. Unless you had some other fail safe in place to prevent it from getting power when the pump is not on and water flowing.
    Has your flow switch failed?
    You can buy replacements of just the switch, but it looks like buying the entire kit (T with sensor and unions) is actually cheaper.
    22,548
    There are return jet units that don't have a flow switch, but if it's not one of those it must have an operating flow switch. It's just too dangerous to operate it without one.
    JoshU's Avatar
    New Orleans, LA
    542
    The AquaRite must be used with a flow switch. If it has failed you will need to get a GLX-FLO-RP switch to replace it with. Replacement is extremely easy and should just take a few minutes at the most. As Bama mentioned their are some "convection" return jet style jets however the AquaRite is not offered in this configuration.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Thanks got one on order!!
