Results 1 to 7 of 7
Thread: Crack in filter casing, how to keep algae away?
    Jun 2007
    NorCal
    92
    We developed a crack in our filter casing and will need to order a new one. In the meantime, since we can't run our pump, does anyone have suggestions on how to keep the pool from turning into a swamp? Should I just pour in bleach and brush to mix? Should I keep it at a shock level or a maitenance level while I wait for the new part?
    17K gallon in-gound pool, black plaster, Polaris 380, cartridge filter system
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Can you run on recirculate without the filter leaking? If you can't do that, I'd try to plumb in some PVC to bypass the filter so you can maintain circulation. It's not filtration that you need to control algae, it's the circulation so you can sanitize.
    Jun 2007
    NorCal
    92
    I don't think I have a recirculate option, but I'll have my husband check. With any luck, our pool store will have the parts we need in their warehouse and we'll be able to get this fixed before too much damage has been done to the water clarity.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Can you do a quick epoxy patch to the effected area to allow you to keep filtering until the new unit is installed?
    Luv& Luk
    -Ted
    The other approach, not nearly as good, is to get a small pump, like a pool cover pump or a sump pump, and use it to keep some circulation going. It won't be nearly as good as the regular pump but it is much better than nothing.
    Jun 2007
    NorCal
    92
    Waste, my husband's reaction to the crack was to apply an epoxy. I am really worried about the possibility of an explosion, so if it comes down to it, I'd prefer to deal with an algae-filled pool rather than take that risk. The filter is running at a pressure of around 25 psi. We just switched out the cartridge last night with a clean one, and the pressure is still that high, even with the leak. So we are going to have to figure out the cause of the increased pressure as well.
    Jun 2007
    NorCal
    92
    Jason, I think that we do have a sump pump, so I'll suggest that to my husband as well.
