Results 1 to 7 of 7
Thread: What priority should these improvements be in?
    Dec 2011
    Charleston, SC
    100
    Hi, Just replastered my 30K gal pool. Startup was done by a pro...now I am looking to begin on my own but I have a couple questions about some improvements I need to consider. Also, I am wondering which of these should be my priority?
    1. Booster pump is leaking...will need to replace it soon...but water does not appear to be leaving the pool as water level has not gone down. Is this something that needs to be fixed now?
    2. Pool is chlorine now....Considering switching to Saltwater. What are average costs for this to be installed? Any useful sites that compare costs? I am curious about the energy costs as I now have a 1 speed pump.
    3. Currently have a weird 2 filter system that is an older style of filtering. These are not in a separate filter tank, they are at one end the pool inside the weirs under the baskets. Does anyone know what this system is called? Pool Pro says the system may work but in liklihood, it will not be sufficient and to wait until the summer is over to see if it will be enough filtration for 30K gallons.
    4. Should I switch to a variable speed pump? I like the energy savings but do they have the ROI?
    THANKS for any suggestions on which I should consider first AND possibly which I should consider doing together?
    IG Gunnite Pool Size: 25K gallons (20 x 40, 3'6" to 6" depth) with 2 huge Baker Hydro cartridge filters under the skimmer baskets on the suction side, 2 mech timers
    BRAND NEW PLASTER! Quartzscapes/Diamondbrite, Newer Polaris 280, Brand New Hayward Maxflo VS, Brand New Pentair Intelichlor
    I will conquer the black algae this pool season!!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: What priority should these improvements be in?
    Salt conversion should wait at least a month or so. Salt can interfere with the curing of the plaster. The SWCG will drive up your pH and with new plaster, you will struggle with your pH for the first year. Might be good to wait until next year.
    Your booster pump may be repairable. Where is it leaking?
    The pump switch may or may not pay off quickly, depending on your electric rates and if your utility or government offers any incentives for energy efficient upgrades.
    38,251
    I just wanted to add that I think the energy cost of a SWG is pretty low compared to your pump. Even if your electrical costs are not very high, you could certainly benefit from a 2-speed pump over the 1-speed ... you need pretty expensive electricity (or great rebates) or special pumping requirements to make the variable have a good ROI.
    One thought though, with the variable pump, you may be able to remove your booster pump completely as the 3HP variable is pretty powerful ... depending on your setup.
    Dec 2011
    Charleston, SC
    100
    Very interested in using the Variable Speed for the booster pump...can this work for the Polaris Pressure Side models? Thanks!
    Jan 2011
    153
    Are the filters inside the skimmers underneath the baskets?
    Dec 2011
    Charleston, SC
    100
    YES They are! What is this type of system called? Its not the traditional filter system at all! I've been told its way old school.
    Jan 2011
    153
    Sorry it's taking sometime to get back busy season again.. Your skimmers are made by baker hydro.. If the skimmers are in good shape I would pull out the filters and install a new filter right after the pump. Baker hydro has been around for probably 20 years.
