Thread: We're Aerating Now!
    Jan 2012
    'burbs of Augusta, Georgia
    7,338
    We're Aerating Now!
    The pool store chemist (grumble grumble) told us to add too much Alkalinity on our initial first test. Two weeks later on testing he said "I told you to add too much" yet offered no solution. That's when I learned I have to depend on my own consistent testing results and ordered my test kit. Its actually been quite interesting and a little fun to tweak the pool myself. We learned here how to lower the T/A using muriatic acid and aeration, and started with a purchased fountain. It just wasn't quite enough so last evening my husband hooked up the small hot tub sump pump with a hose aimed over the pool. Its doing the trick! We started out yesterday with a T/A of 200, and this morning's reading is 150. I've been keeping the automatic cover off and only running the fountain/sump when I'm awake to monitor it, and checking & treating that pH often.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: We're Aerating Now!
    Yep, there is no substitute for a good test kit!
    Also sounds like you have a good handle on what you are doing
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    If you're having this much fun with a new test kit, you can double it with a speedstir.
    With a test kit and the pool calculator and just a little bit of smarts, you'll have the pool chemistry perfect in no time. And it will stay that way. A few weeks ago I had a friend over and we were on the patio smoking cigars. He wandered over and stared down into the pool and said, "I thought you were exaggerating when you said you could tell the screws in the drain were phillips head!"
    Quote Originally Posted by Richard320
    I know what you mean, such a bummer. I can see dirt on the bottom from the kitchen window.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
