Become a TFP Supporter Pool School
Results 1 to 7 of 7
Thread: Need To Reset Pentair Intelliflo
    Senior Member Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    Can anyone tell me how to clear alarms on the intellflo? While I was at work today my electrician came out and added some breakers. Prior to doing so he shut the power off to the Easy Touch panel. Once powered on again, the pump is flashing the red alarm light, and shows power failure. I've tried everything and cannot get the pump to come on now.
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Senior Member
    NJ
    291
    Re: Pentair Intelliflo
    On mine you just hit the stop/start button and then the reset button.
    20x40 IG vinyl, heatpump and solar and 3 siberian huskies, 10kw PV solar electric system. Nikon Photographer D800e dSLR.
    Jan 2012
    West KY
    243
    Thanks kirbinster. Tried that without success. I found instructions here for a factory reset. Think I'll try that when I get home today.
    TF100 Test Kit
    SpeedStir
    Jan 2012
    West KY
    243
    Re: Need To Reset Pentair Intelliflo
    Got pump reset and going...
    Sent From My Inspire 4G Using Tapatalk
    TF100 Test Kit
    SpeedStir
    Mar 2012
    Lebanon,Tn
    45
    Quote Originally Posted by Bluegrassman
    What did you have to do to reset?
    21x42 olympic sports pool
    18000 gal
    Intelliflo vs pump
    Pentair ic40 SWG
    Suntouch control
    TR100 Pentair sand filter
    Letro ledgen II pool cleaner
    Vinyl liner
    TF Test Kit's TF100
    Jan 2012
    West KY
    243
    Press all 4 buttons on top row at once, then top 2 middle buttons and select and escape buttons at same time, then cycle power off/on
    TF100 Test Kit
    SpeedStir
    Jun 2012
    Escondido, CA.
    42
    Quote Originally Posted by Bluegrassman View Post
    Nope!
    Escondido Ca [*]~23000 gallon plaster pool built in the 70's[*]Pentair VF Pump running 10hrs at 1800rpm getting and estimated 35-40 GPM thruput[*]Sta-Rite Cartridge filter
