Results 1 to 11 of 11
Thread: Should I go salt?
    Should I go salt?
    I see so many of you posting salt results in your testing, and I have heard many people talk about liking the way the water feels. Is there an article I am missing in pool school about salt? What are the pros and cons to implementing salt? How does one go about making this addition to a pool?
    Thor
    Yuba City (Near Sacramento) CA
    3,000 Gallon, IG, Fiberglass
    Cartridge Filter
    Hayward Northstar
    38,262
    Re: Should I go salt?
    Personal preference really. Odds are if you have had your pool for awhile and using bleach, your salt level is well above zero ... maybe in the 1000ppm range.
    SWG generally require 3000-3500ppm of salt, but I have read posts here about people adding salt up to 2000-2500ppm without a SWG just for the "better feel". Note that the ocean is around 35,000ppm.
    There are a few things to consider. The salt water may be a little harder on metal around your pool and some natural stones (coping etc) could be damaged by the salt.
    If you want to add salt, it is as easy as buying a few 40 lb bags (look for Solar Salt at HD/Lowes/etc which is about half the price of "pool salt"), dumping them in the pool, and brushing the salt around a bit until it dissolves (usually within 10 minutes from my experience).
    EDIT: For your pool, each 40lb bag will raise the salt by about 250ppm. And each bag costs about $5.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    For your reading pleasure: http://www.troublefreepool.com/can-y...alt-t6006.html (the link to this thread was hidden in the further reading section of pool school)
    38,262
    Quote Originally Posted by linen
    I knew I had read a post about this somewhere
    I'm in! Thank you both. The thread you linked sold me!
    Thor
    Cartridge Filter
    Hayward Northstar
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by moljourn
    So since we are selling ...how bout a swg to go with that salt?
    Hahaha! I'm already looking online. What models should I be looking at?
    Thor
    Cartridge Filter
    Hayward Northstar
    38,262
    Well, the recommendation seems to be to size the cell for 2-3X your pool size. So look in the 40k range on the cells. Theoretically since they are not run as hard/often they will last longer and offset the higher cell replacement cost.
    I only have some experience with the Hayward line with my old pool and going to be installing one on my current pool. Reading around here they seem like a middle-of-the-road option.
    May 2012
    Arcadia, Ca
    50
    We just installed Pentar? And some device called the IMPULSE 3000? It supposedly keeps the SWG clean?
    24'x15' 4.5 deep (avg) 13000 gallon pebble bottom in ground playpool
    Cartridge filter with a hayward 2.5hp pump.
    Wish I knew more about that stuff. I am going to hold off on putting an SWCG in. I just added salt to my pool for feel. I plan to keep it around 2000ppm and haven't been in yet (maybe this weekend) but can tell just by touch that the water feels AMAZING!
    Thor
    Cartridge Filter
    Hayward Northstar
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    SWG - Here is my opinion. I have a 2 foot waterfall from my hot tub to my pool, so I need to add about 16 oz of muriatic acid each week. Besides that, my levels are constant from March through October. Very little maintenance except for cleaning. Couldn't go without one.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
