Results 1 to 11 of 11
Thread: Valve leaking on sta rite filter!! Help!!
    The valve just stared pouring water after I had backwashed. It is a sta rite model T-210wf. Do I have to replace the valve or can it be repaired.
    30,431
    Re: Valva leaking on sta rite filter!! Help!!
    I have to assume it's a multi-port valve attached to the top or side of your filter. Perhaps it simply didn't get seated correctly in the slot provided.
    If you are unsure what type valve it is, post a pic and we'll help you get it fixed.
    Yes it is a multi-port valve. It leaks in all positions. The handle is kinda lose.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    It is repairable and isn't really that complicated.
    What do you think the problem is? I took the handle of, and seemed to be some kinda lub or grease type stuff.
    22,553
    It sounds like the spring is broken. It'll be under the top works and since you have to pull it apart anyway I'd go ahead and replace the spider gasket and o-rings while I had it apart.
    SW Indiana
    9,199
    Your valve probably has a replaceable diverter assembly, the top of which is the part the handle pins to. If you take all the bolts out around the valve, you can get to the spring and diverter and see what has happened, assuming your plumbing has unions to let you lift the top off the valve.
    Thanks for the info, I have been looking on line for a good parts site and a diagram, any help with a link? Thanks
    SW Indiana
    9,199
    Quote Originally Posted by Bonnie F
    Can't find anything so far.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Go here and find out which head you have.
    http://www.inyopools.com/pool_part_cat_ ... Parts.aspx
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    Thanks for the help, got it took apart and ordered parts.
