Results 1 to 9 of 9
Thread: Solar Cover Reel - W/gears and W/out?
    Does anyone have input into these two reel systems and if it is worth the extra $$ for the geared unit vs the non?
    $239
    http://www.solarcovers.com/product/sola ... 21-ft-wide
    $179
    http://www.solarcovers.com/product/sola ... 20-ft-wide
    Thanks!
    Ted
    Dec 2010
    San Diego, CA
    1,137
    Re: Solar Cover Reel - W/gears and W/out?
    Your images do not display...
    15,600 Gallon, 16' x 32' In-Ground Vinyl Pool
    Pentair VS 3050 pump, Quad DE 60 filter and SunTouch controller
    8 gallon Liquidator, Aquatherm EcoSun Solar Panels, 2 wheel ThePoolCleaner
    Sorry... fixed.
    22,542
    I don't think it makes a big difference in rolling it unless you have a huge heavy cover or are very small or weak.
    I prefer less moving parts, so I'd go with the one without gears, but that's a personal preference.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    No gears on mine and no problem with a 30ft cover. Agree with Bama 1 less thing to break.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
    Wife is 5'4 and 112lbs.... so wasnt sure. Cover is a good portion of a 20x40 rectangle cut to shape.
    22,542
    And that's the reason for my qualification of a small person trying to roll up 40' of 12 or 16 mil cover. In that case I'd probably go with the gears. Although she's probably going to have a problem moving it once she gets it rolled up. I'd look at a 4-wheeled reel also.
    Jul 2010
    Central, New Jersey
    31
    Hey Ted
    Which reel did you end up with, I am looking at the same exact reels as you were and just posted the same question, (Guess I should have used the search better):
    solar-cover-reel-geared-or-standard-t44245.html
    Please let me know your thoughts.
    -Craig
    Pool: 20 X 40 Rec - 28,500 gallons;
    Type: IG with Vinyl Liner
    Filter: Hayward 46SqFt DE Filter
    Pump Size: Hayward Super-Pump 1 hp
    The non-geared unit is what I went with (your option 1). So far, so good.
