Thread: Fighting PH
    Fighting PH
    I just recently did a complete drain and have been working to get my PH inline. It seems to keep going up after I work it down with MA. I've been adding acid for a few weeks, as my PH would come down to 7.6 the work its way back to 8 a few days later. Just wondering if this takes some time to level out or am I missing something? I've only about 2/3 of a gallon of acid in a three week period.
    FC - 3
    PH - 7.8 ( it was 7.6 the other day)
    TA - 100
    CYA - 30
    Thanks!
    14,387 Gallons; Sand Triton II TR 100; IG; Pebble; WhisperFlow 1 1/2 HP Pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    Re: Fighting PH
    Sounds normal. You still have semi-high TA, which tends to push pH up. And if you have a spa or a waterfall or anything at all that aerates things, it makes it do it faster. When you plug numbers into Pool Calculator, down near the bottom you'll see "Effects of adding chemicals." Plug in whatever amount of acid it calls for and you'll see that although it may lower pH a fair amount, it has very little effect on Total Alkalinity. So you have to do it over and over and over. Eventually, you'll get TA down to the sweet spot for your pool and pH will stabilize.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Fighting PH
    Each time the pH rises to 7.8, lower it back to 7.2. Over time, this will lower the TA which will help slow the pH rise.
    Also, if you have any water features or even returns that break the water surface, that will cause the pH to rise.
    This pool is more than one year old, right?
    You're done SLAMing when:
    38,452
    Re: Fighting PH
    Read the article in pool school about lowering your TA. That is probably what is pulling your pH up.
    Re: Fighting PH
    Not sure of the age of the pool, less than 10 years. I don't have any water features. I'll check out the TA info on here and work from there. Thanks everyone!
