Thread: What is the difference between these salt levels?
    iggy's Avatar
    Jan 2008
    The Cool Part of Arizona
    175
    I just checked my Goldline Aqua Rite panel and looked at my readings.
    The only question I have is what is the difference bewteen the two salt level readings that show up.
    Panel
    Salt Level 3400
    Instant Salinity - 3100
    In the manual it really never mentions what is the difference between the two numberes.
    Should they always read the same but one will be a negitive number?
    I also found on line the install package and it talks about locking the salt ppm in by using a sequence of switches.
    Can someone explain my numbers.
    Oh everything is normal
    FC 3
    ph 7.8
    CA 250
    Alk 120
    CYA 75
    Clear water
    Iggy
    In-Ground SWG pool 11,000 gal., Jandy CL460 Filter, 1.5hp Stealth Jandy pump, Paramount PV3 In-Floor cleaning sys., Goldline SWG, Hayward Color Logic 2.5 LED Light
    mas985's Avatar
    Pleasanton, CA
    11,743
    Instant salinity is just that, what the SWG reads as the salinity at that point in time. Salinity is determined from the voltage, current and temperature in the cell. Instant salinity is updated every second or so.
    The other salinity usually shown in the default menu is an average over several run cycles. Since the instant salinity can be influenced by many different things including temperature, they have a second reading which is averaged over several cycles such that a more long term reading is available and usually more accurate than the instant salinity.
    Mark
    iggy's Avatar
    Jan 2008
    175
    Here is the Hayward/Goldline answer to my question above.
    Very interesting stuff but not in the manual.
    Iggy,
    The display that is shown on your panel is the AVERAGE salt level, the unit works on two sides so what you see as an instant salt level is what's going through the cell at that moment, the unit will then shut off and turn back on to get reading for the opposite side. The unit averages both sides of the cell and that's what is shown on your panel .
    Hayward Technical Services
    One Hayward Industrial Drive
    Clemmons, NC (USA) 27012
    866-429-7665
    Useful links
    Builder/Dealer/Service Center Locator:
    http://www.haywardnet.com/locator/
    Owner's Manuals:
    http://www.haywardnet.com/inground/products/manuals.cfm
    Frequently Asked Questions:
    http://www.haywardnet.com/contactus/faqs/
    May 2014
    Louisiana
    2
    Re: What is the difference between these salt levels?
    Hello! New to this site and having just converted to SWC, had the same question. The INSTANT salinity reading is preceded with a - to differentiate if from the default reading which is not. Hope that helps! Would appear that all is cool
    Jul 2015
    Houston, Texas
    7
    I was wondering the same thing. Under what conditions would you want to manually add the instant salt level into the average salt level?
