Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Booster pump won't come on (video included)
    Dallas, TX
    227
    Came back from our of town and booster pump won't run. It tries to kick on, and makes the sound in the video below for about 10 seconds. If I don't turn the switch it will do that about every 2 minutes.
    Any ideas what the problem is? I replaced the front cover (leak) 15 days or so ago, but it was fine when I left on Friday.
    http://www.youtube.com/watch?v=G8HMnQ0o ... ata_player
    new house: TBDK gal IG plaster pool, filter Titan CM DE filter 36 sq ft , 1.5 HP Pump; Polaris 380
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Re: Booster pump won't come on (video included)
    Can you rotate the shaft on the pump?
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Dallas, TX
    227
    Quote Originally Posted by maxepr1
    How do I attempt that?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Take off the cover in the center of the motor(on the back side). Once the cover is off that will expose the motor shaft. Use a wrench and see if you can freely spin the shaft.
    Dallas, TX
    227
    Does the power need to be off to do this?
    Jan 2011
    153
    It's either a bad starter capacitor, locked up motor or dirty contacts in the motor.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Quote Originally Posted by CarrolltonTXPool
    Yes make sure power is off!
    Dallas, TX
    227
    Ok, got the cover off and the motor shaft spins freely, even by hand. Next step?
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Then I would be looking at the start capacitor.
    Dallas, TX
    227
    Ok. I've taken one off before, but how do I test it again?
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    The best test of a capacitor is to just swap it out w/ a known good one. They're cheap, relatively speaking.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Capacitors can be a little dangerous if not careful, cheaper to just replace it.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Not sure if polaris boosters have centrifugal switches or not? Ohm_Boy?
    Dallas, TX
    227
    I can't seem to find them online. Are they that much cheaper to buy online than at a Leslie's? Or since it's electrical, can I get it at a non pool place for cheaper?
    Jan 2011
    153
    You can buy them at Leslie's or any place that rebuilds electrical motors..
    Dallas, TX
    227
    Quote Originally Posted by Keven
    ok thanks. just didn't want to pay 50% more a ta pool store if it wasn't necessary.
    Mar 2012
    Northern California
    59
    Most any place that rebuilds electric motors and even most small tool repair shops will have a capacitor tester and will test yours for free. (if you want to bring it to my shop in Nor Cal I'll test it for you) Capacitors for motors like that will run anywhere from $20 to $80 and should be relatively easy to find.
    32,000 Gallon Plaster Pool
    Hayward Aqua Plus 40k Gallon Chlorine Generator w/ Controls PL-PLUS
    Pentair IntelliFlo Variable Speed Pump
    Polaris 3900 Sport Automatic Pool Cleaner
    Polaris 3/4 hp Booster Pump
    Pentair/PacFab Nautilus D.E. Filter 48 Sq Ft
    Dallas, TX
    227
    this look like it?
    http://www.grainger.com/Grainger/DAYTON ... Pid=search
    Matches this one on epool.com that says it runs most Polaris booster pumps
    http://www.epoolshop.com/runcapacitor12 ... 2-3/4.aspx
    I'm pulling mine at lunch today to make sure.
    Guy at leslies said they are about $70 and if it is bad the motor is about to go to and i should replace the whole thing for $299.
    Yeah, no thanks!
    Dallas, TX
    227
    pulled mine and it llos like this:
    the MFD rating matches, but i can't find any on the capacitor website that match that MFD with 165 VAC. (the one in the link above is 110:125). is that a problem.
    found this one that matches, but was hoping to get one local:
    http://www.temcoindustrialpower.com/pro ... C0092.html
  20. Back To Top    #20
    22,553
    If you can find one in the right capacitance range and equal to or greater voltage range it'll work fine.
    Most likely the 110 - 125 volt one will work fine. If that's all you can find locally I'd go with it.
