Thread: Installing a new Jandy cell- retrofit old one
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Can I somehow take the existing tailpiece after removing the nut via saw and fit it to the new coupling nut by using a 2" coupling connecting the old tail piece to the new? I believe the old style was a 2" - 2" and the new is 2" - 2.5".
    My tailpiece is glued to my 3 way valve....trying to avoid removing the valve and replumbing all that, water feature and pool return. I can redo the input end from filter pretty easily and have room there after I remove the T that contains the sensor.
    Dang pool builder wants to charge $200 just to come out ...... and $90/hr labor to put in the new cell...that's just robbery IMO for a unit that is 6 mos out of warranty.
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    22,548
    Re: Installing a new Jandy cell- retrofit old one
    If you can post a pic of it we'll have a better idea of what will and won't work.
