Thread: Just switched to cellulose from DE...
    May 2009
    Dallas, TX
    782
    Clean filter pressure has always been 11-12 psi with DE. It is currently at 10 after adding recommended amount of Zeofiber. I'm tempted to add a little more, but I was very careful measuring the Zeofiber, so I'm certain I put enough in according to directions.
    What do you think? Add more, or leave it alone?
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Just switched to cellulose from DE...
    Zea posted a couple of years ago that start pressure was a little lower with fiber than DE.
    cellulose-instead-of-de-t20252.html
    May 2009
    Dallas, TX
    782
    Quote Originally Posted by JohnT
    Thanks for reminding me of that thread. I should have remembered, considering I started it!
    I'm glad I resisted the temptation, but it wasn't easy...I'm a certified overdoer.
