Thread: Help picking out a SWG for 15x26 oval above ground pool
    We are purchasing an above ground pool kit and having someone install it. However, we don't know what kind of SWG to purchase. Does anyone have any recommendations for a pool this size? We intend to have someone service it for the first year to help get our levels right.
    16000 Gal. Kidney / Gunite / South East Florida / Taylor K2006 Test Kit / Hasa Liquidator C201
    Jandy CS100 / Sta-Rite U3 Skimmer / Pentair Great White / Single Floor Drain / Single Return
    I'm still learning and I know nothing!
    Oct 2011
    New Caney, Texas
    414
    Re: Help picking out a SWG for 15x26 oval above ground pool
    Welcome to the forum!
    I will leave it to the pros to recommend a size for your SWCG.
    You will need a good test kit and you cant beat the one listed in my signature below.
    You can manage your own pool cheaper with a proper kit and POOL SCHOOL (see my signature)
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, cunnis
    Assuming a 4 foot water depth pool (54" wall minus 6" to water level), it looks like yours will be ~10000 gallons. If you want to go the cheap route look into the intex swg. Others may have some thoughts...
    Quote Originally Posted by cunnis
    With all the information and help here on tfp, you might want to consider saving you money and doing it yourself
