Results 1 to 10 of 10
Thread: Noisy New Pump
    Noisy New Pump
    Hello -
    I have an uprated 1.5hp whisperflow two speed pump that is brand new (on a brand new pool).
    -It is very loud when on high with both the returns and spa jets on.
    -If I turn on only the spa jets, it returns to a normal noise level.
    -If I turn on only the returns it is very noisy.
    -If the pump is on low, it has a good noise level no matter what setting I have for the return/spa set up.
    What can I do to fix the issue? Also, is this something my PB should fix?
    Thanks!
    17'x36' Freeform (Omni/Gemini shape) Polymer Vinyl Liner Pool; Made by Hydra Pools; 6' Water Depth; Cantilever Concrete Stamped Coping; 8' Radius White Step; 8' White Cozy Cove with 6 Jets; 1.5 HP Pentair Whisperflow 2-Speed Pump; Pentair Clean and Clear Plus 420 Cartridge Filter; Kreepy Krauly Legend Pool Sweep; 2 Skimmers; 4 Returns; 2" Rigid PVC; Pentair 5G LED Light; Pacific Ultra Mesh Safety Cover; Pentair Intellichlor IC 40; 3 Deck Jets
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Noisy New Pump
    Is the strainer basket full when it is noisy?
    Re: Noisy New Pump
    Hi John! The strainer baskets are empty both in the pump and at the skimmers... Any ideas on how to fix?
    38,284
    Re: Noisy New Pump
    Hmm. I thought he meant full of water ... not debris.
    SW Indiana
    9,199
    Re: Noisy New Pump
    Quote Originally Posted by griff3333
    Check that your pool water level is at the mark on the skimmer face or about halfway, and that the skimmer weir moves freely.
    Re: Noisy New Pump
    Oops... sorry. The water level is about 2/3 of the way up the skimmer plates.
    Re: Noisy New Pump
    Wier doors are functional as well...
    Re: Noisy New Pump
    Bump
    38,284
    Re: Noisy New Pump
    Could there be a blockage in the pool return causing the pump to "work harder"? although that does not make sense that it would be load when on both return circuits.
    What do your pressures look like for the various combinations of returns?
    Re: Noisy New Pump
    I read something on another post indicating that potentially having not enough resistance may cause a loud pump - is this a possibility?
