Thread: have to drain intex ultraframe
    Hi all! I have a quick question. I have a the 16x32 rectangular intex pool n need to drain it. We have had it up since last summer but have had a huge amount of rain in the past three months that caused two of our legs n paver pads to sink in the ground this has put a bad bow in the side rail that I am scared will break. So on to the question, if I drain it will that cause the liner to crack , I have read other post that say u can't drain an above ground pool but I think that only applies to the metal sided ones. Or I hope so anyway. Secondly can I drain it with a sump pump or should I use my filter? Anyway sorry for the long post thanks for any advice in advance
    22,553
    Re: have to drain intex ultraframe
    The Intex pools are designed to be drained and stored so draining it won't hurt it.
    You can use your pump to a certain point and then you're either going to have to use a sump pump or a siphon. The sump pump will most likely be less trouble.
