Thread: 2 speed WhisperFlo pool pump makes noise - video
    Fleur's Avatar
    Jul 2011
    Phoenix, AZ
    24
    While reading forums I came across this topic Whisperflow pump making NEW STRANGE LOUD noise!
    X-PertPool suggested that it sounds like bearings.
    One of our 2 speed WhisperFlo pumps also makes a very loud noise
    Video is here.
    Is it possible that we have the same problem with bearing? We had this noise from the day we bought the house, so for 9 months the pump was working while making these strange sounds. Maybe it got a little bit worse lately, but I’m not 100% sure.
    Is it bad to let the pump run while it is making this noise? We had 2 different pool companies who performed monthly service + one guy from Leslie’s – no one said anything regarding this noise.
    Thanks!
    AG SWG ~15,000 Pebble Tec + Spa :: Intellichem, SWG IntelliChlor IC40, Pentair Intelli pH, Clean & Clear Plus filter (spa), Triton II Sand Pool Filter, MiniMax NT heater, Jandy NeverLube valves X8
    Pentair IntelliFlo 3HP VS (pool filter), WhisperFlo 3 HP 1.15 SF (hot tub jets), SuperFlo VS (spa filter), Challenger 1 1/2 HP 1.47 SF (water features: spillway, fountains)
    22,551
    Re: 2 speed WhisperFlo pool pump makes noise - video
    It's most likely bearings and sometimes they can run a very long time making noise before they fail completely. While it doesn't do the pump any good to run that way, it probably won't tear something up completely even if it fails and stalls the motor. I'd have it looked at as soon as I could but it's not a dire emergency.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
