Thread: Putting the Pentair filter back after cleaning cartridges
    New2water's Avatar
    Jun 2011
    Stockton, CA
    53
    I opened my Pentair CCP320 filter today to clean the cartridges but failed to remember how the compression spring was installed above the air bleed tube assembly. The owner's manual does not have clear pictures.
    I am attaching two pictures as possible ways and will appreciate advice to do it right. Thank you.
    18K gal in ground, Plaster, three 1 HP WhisperFlo WFE-4 pumps (Pool, Hot Tub, Waterfall), 320 sq ft cartridge filters, MiniMax Plus HP 400 heater, TF-100 test kit, Kreepy Krauly Classic cleaner
    22,548
    Re: Putting the Pentair filter back after cleaning cartridge
    The P_1 pic is the correct way. If you take a look at this pic you'll see how it goes.
    New2water's Avatar
    Jun 2011
    Stockton, CA
    53
    Thank you for your help. I will put it correctly in the morning.
