Thread: Landscape Lighting
    pooly1's Avatar
    Mar 2012
    Michigan
    107
    Landscape Lighting
    I want to add a couple lights to my shrubs to give them a green glow.(Everyone's night pics look amazing!) Should I use a flood light or spot light style? Also how many watts ? So many options I just have no idea.
    16 x 32 Inground Vinyl 21000, 2 returns, 1 skimmer, 1 main drain. Raypak Heater, Crystal Flo Sand Filter
    Re: Landscape Lighting
    For a shrub I would use a flood light under the front of the shrub pointing up at the shrub. You would only need low wattage such as a 20w halogen or led equivalent.
    If you look at home depot there are low voltage lighting packages that have everything you would need.
    35,000 gal, 3.5-9ft with diving board. Jandy CV580 filter, 2hp 2 speed motor, Pentair Ultra Temp 120 H/C heat pump. Pentair IC60 swg.
