Results 1 to 9 of 9
Thread: Wiring 220V Toggle Switch for new Pump
    Jun 2011
    San Diego California
    88
    I replaced my old 2HP pump today and when opening the old toggle switch box, there was a fair amount of corrosion on the toggle switch. I picked up a two pole (30A) switch which showed the two hots connect to the bottom two screws (one on each side) and then the switch activates the two legs from the two top screws (one on each side).
    The old switch I pulled out was wired like a common 115V with two hots on one side, and then the legs on the other.
    Am I missing something? I wired it up as the manufacturer diagram. I can always check to see if both legs are dead when switched off, and both live when on, but I figured I'd ask here before throwing the breaker in case the pump could get upset if it sees only 115V of one leg, if I'm missing something.
    Here's the wiring diagram, and how I wired it. The Load here would be the pump.
    [attachment=0:19f0yn2o]2pole switch.JPG[/attachment:19f0yn2o]
    IG, 13,000 gal, concrete, DE, VS Intelliflo Pump, Intellichlor SWG
    San Diego, Ca.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: Wiring 220V Toggle Switch for new Pump
    That should do it.
    22,548
    X2.
    Just to interject, a lot of 220 volt pump installations only switch one leg. I don't like that, but it's done a lot.
    May 2009
    Youngsville NC
    395
    Using the DPDT switch (as in OP's original post - switch is out by pump) is exactly how I have my pump hooked up after the timer in my shed. IMO, not doing it this way is setting yourself up for a potential shock or worse.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Jun 2011
    88
    X2.
    In the manual for the intelliflo, it stated both legs should switch at the same time. So as long as the switch manufacturer's drawing is correct, that is what should happen.
    Quote Originally Posted by scooperhsd
    Yep. The way it was wired previously seemed to leave one side of the load always hot, which woudl surprise someone if they thought the switch truely meant "off" when switched to "off".
    San Diego, Ca.
    22,548
    That's the reason I don't like just switching one leg. Even though you should make sure the breaker is off before touching it.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Naturally, switching one leg is common for 120V, where only one leg is hot.
    I hate to be this blunt, but wiring 220V that way is, in my opinion, irresponsible and dangerous, and done by people who don't want to put forth the time, money, or effort to do it right.
    22,548
    Quote Originally Posted by Ohm_Boy
    Completely agree! My note was more of a warning so someone doesn't get caught off guard.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I should add to that:
    ...done by people who don't want to put forth the time, money, or effort to do it right.
    or have no business doing it at all.
