Results 1 to 11 of 11
Thread: Motor Housing leaking
    May 2011
    Orlando, Fl
    36
    Marathon electric 1081 pool pump
    http://ecx.images-amazon.com/images/I/516S%2BGWh4nL.jpg
    That what it looks like. Its leaking where the silver mount meets the black portion on the underside of the motor does anyone know what i should do next?
    20K gal • Cartridge Filter • IG Pool • Plaster • 1hp pump
    Jan 2011
    153
    Re: Motor Housing leaking
    Check your pump seal.
    22,544
    Leaking between the motor and pump is most likely a seal leak.
    May 2011
    Orlando, Fl
    36
    so how do i fix that?
    22,544
    You have to take the wet end (pump part) off the motor. The best thing to do is take the pump out and take it to a motor shop or pool store and have them replace it.
    May 2011
    Orlando, Fl
    36
    ok isnt the whole thing the pump? When you say take it apart are you meaning the black portion or the black and metal portion? Disassemble that portion from the "propeller" or fan correct?
    22,544
    The pump is two parts, the motor and the wet end. They're collectively called a pump.
    I'd just take the whole pump out and take it to a pool store or motor shop.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    You tube Nate. Also do a search on here for Whisperflo seal replacement, there are good instructions and pictures. Even though you don't have a Whisperflo It's basically the same, different seals of course.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    May 2011
    Orlando, Fl
    36
    Oh ok great! thanks for the help... You think its that easy I can do it myself?
    May 2011
    Orlando, Fl
    36
    Its so funny i switched to the BB method last year and right after i got it Perfectly blue and swimmable my Filer blew,...fast forward and i finnally got this sucker blue again and booom !
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Yep! I'm getting ready to do my pump as soon as the seals get here!
